17x8 bmw wheels fitted to series iii
Old Jul 25, 2018 | 10:20 AM
DerekXJ6's Avatar
Default 17x8 bmw wheels fitted to series iii
Old Jul 25, 2018 | 10:26 AM
DerekXJ6's Avatar
I'm still working through the center caps on the front due to the size of the hub. Initial modifications are promising, just need to make the mounting tabs a bit smaller to fit between the wheel and the hub. Rears fit no problem.
I went with some pretty wide 225 55 17 from Bridgestone, they run wide for 225s. Maybe a narrower 225 or even a 215 would have worked better. Had to roll the rear fenders. May need a bit more rolling.
Old Jul 25, 2018 | 10:55 AM
moronthethrottle's Avatar
I like them, they have a natural, not overstated appearance.
Old Jul 25, 2018 | 11:32 AM
DerekXJ6's Avatar
Thanks. I wanted to keep a significant sidewall to keep with the character of the car. 17" was the right compromise for me between looks and performance.
The e39 wheels have a 74mm hub bore and 5x120 pattern making them an easy swap.
Old Jul 28, 2018 | 09:55 AM
DerekXJ6's Avatar
Successful in the modification of the front center caps. I had to cut some of the inner structure and drill a hole in the center because it was the low point of the center cap.
Old Jul 28, 2018 | 10:00 AM
DerekXJ6's Avatar
Now I just need to order 4 new center caps and 4 70mm leader emblems.
MRomanik
Apr 14, 2012 08:30 PM
ryawee
Feb 26, 2011 07:33 PM
chknhwk
Nov 14, 2010 07:36 AM
the-jag-guy
Apr 15, 2010 10:34 AM
dgrelecki
Jan 3, 2009 08:00 PM
