1974 XJ12 Non-Functioning Carburetors
Old Dec 3, 2023 | 07:13 PM
XJ12C_Driver's Avatar
Default 1974 XJ12 Non-Functioning Carburetors
Good to be back again !... motivated by my recently acquired 75 XJ12C !
however, this even more recently acquired 74 XJ12L has me stumped ( sat for about 10 years )
It simply WILL NOT run on the carburetors.
ALL variables ( fuel quality / delivery, vacuum, ignition efficiency ) dealt with.
By introducing fuel directly into the intake manifold plenum, I HAVE CONFIRMED that the engine does run, and actually sounds pretty good.
Seems that all the carburetors do not allow any fuel whatsoever, through their metering system(s), and into the manifold / engine.
I have been doing carburetors, tuning race engines, ect, for 45 years, so I should have an idea what I'm doing !....
BUT...
I have never worked with these side draft style carbs before.
Hoping somebody can guide me on what to do to make these Stromberg / Zenith carburetors work again.
Old Dec 4, 2023 | 02:54 AM
xjtom's Avatar
you can download pdf files on those carbs from my library for free. listed under stromberg, > https://www.jaguar-wiring-schematics...fo%20pages.htm
they have a cold start system but you can do a little bush mechanics, you can wedge the pistons up about 1/2 inch or more & watch for fuel coming up the main jet while cranking, as i said - bush mechanics - i'm guessing you've confirmed fuel in the carbs...........
Old Dec 4, 2023 | 04:21 PM
Thanks, Tom... Yes, I had tried just that... propped up the "plungers".
No fuel flow.
A few years ago, some clown broke the steering wheel shaft at the hub. I'm just about to install a new one, and get the steering wheel back on.
maybe that will help
gtcoastie
Mar 30, 2021 08:37 PM
tomcoo
Jul 6, 2020 03:47 PM
Boo
Sep 16, 2016 04:11 PM
giamber
Apr 23, 2013 08:53 PM
sergez
Mar 3, 2012 12:43 PM
