1979 xj-6L cutting out
Old Jan 12, 2025 | 03:18 PM
Spaguy530's Avatar
Default 1979 xj-6L cutting out
Bought yesterday while driving home after about 2 hours car started shuttering around 55 tach was moving all over. Fluid levels look good car not running hot . In excellent condition for its age . Next day car starts and runs good but when you drive it cuts out under acceleration and also died a couple times . Also during all of this the throttle got stuck open . Got it home it runs and idle good still cutting out any ideas !!!!
Old Jan 12, 2025 | 04:45 PM
iramphal's Avatar
My first inclination would be to address the sticking Throttle issue. Would not want that on a highway! May just need a lube job. If i's fine when started, perhaps it's a heat related issue on the cable. I would pay a great deal of attention to that cable. If it starts from cold and starts cutting out once warmed up, I would suspect the coil, or the wiring to the coil, or the ignition/injection grounds located on the RH side of the engine at the rear of the intake manifold. Just my two cents.
Old Jan 12, 2025 | 05:20 PM
Spaguy530's Avatar
Thank you I will start with that is the 79 considered a series 2 or 3 try to find the throttle cable
Old Jan 12, 2025 | 07:10 PM
Doug's Avatar
Series II
Old Jan 12, 2025 | 08:00 PM
jbellK75's Avatar
Nice looking Jag. Stately color. Congrats.
Old Jan 18, 2025 | 11:56 PM
Spaguy530's Avatar
Default Update on the 79
The second tank ended up having bad gas . I cleared the fuel line changed the fuel filter plugs and the coil . Took on a short drive today and I made it home 🍾. Still waiting on a new throttle cable. Also the fuel filter was under the air cleaner
tobywood13
Feb 27, 2024 03:05 PM
Chap1958
Jul 12, 2020 06:30 PM
Some Day, Some Day
Apr 9, 2020 09:25 PM
K.Westra
Aug 30, 2019 10:18 PM
l3uddha
Nov 4, 2012 10:17 AM
