1983 XJ6 Fuel Pump Replacement
Old Feb 10, 2021 | 11:34 AM
Starcaster's Avatar
Default 1983 XJ6 Fuel Pump Replacement
I’m looking to replace the fuel pump on my XJ 6 but I’m struggling to find and material on how to properly replace the part. I was hoping to get a lesson in doing so, or to be led in the direction of some proper instructions, it would be very helpful. Thank you in advance!
Old Feb 10, 2021 | 01:45 PM
Jose's Avatar
it is very easy and logical.
disconnect the battery.
remove all the floor carpet, the panels, and spare tire from the trunk, remove everything.
get an old towel and rubber gloves.
disconnect the two cables from the pump.
undo the nuts and bracket holding the pump,
disconnect the fuel lines at the pump protecting the floor and hands from any fuel spilling, with the towel and gloves.
transfer the foam isolator and bracket to the new pump.
replace new pump with bracket to the floor mounting, tighten nuts.
reconnect fuel lines and wires.
reconnect battery
restart engine.
check for any leak.
reassemble trunk panels, everything else that was removed.
XxX_ANGEL_XxX
Jul 11, 2018 08:32 PM
Wannabeted
Jul 10, 2017 06:02 PM
Dion Baker
Oct 12, 2016 05:11 PM
Mad_Russian
XJ40 ( XJ81 )
Jun 15, 2016 11:15 AM
Du'aine A Samuels
UK & Eire
Oct 22, 2015 01:25 PM
