4.2 flywheel removal
Old Feb 8, 2014 | 12:50 PM
Napoleon Solo's Avatar
Default 4.2 flywheel removal
I'm pulling the flywheel off my 4.2l to start the engine rebuild. The 10 standard bolts and locking plate came off without issue but what needs doing to remove the two locator pin style bolts? Allen key?
Stumped.
Old Feb 8, 2014 | 02:37 PM
JgaXkr's Avatar
The way I was taught was to take a long 5/16 fine bolt with a washer on it. Then find a deep socket to go over the dowel. The next step is to screw the bolt in thru the socket, this will the draw out the dowels. You want to make sure the bolt only come about 1/2 beyond the socket so as not to bottom out on the crank.
Old Feb 8, 2014 | 03:27 PM
Awesome. I'm going to my shop to do it right now...
FrickenJag
Jun 16, 2025 02:15 PM
RoyLittle0
May 25, 2023 02:38 AM
Quantico
Oct 13, 2015 10:34 PM
simongulliver
Sep 16, 2015 03:40 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
