4.2 front and rear seals
Old Feb 16, 2014 | 02:33 AM
hooter's Avatar
Default 4.2 front and rear seals
Putting my engine together[recon head,new bearing shells,timing chains,hone and rings] i stupidly trimmed the rear main rope seals to fit befor reading that they should be massaged into place so will replace befor refitting engine, now with the sump off and the harmonic ballancer removed if i shine a torch on the crankshaft end i can see light through the seal on the underside of the crank and this does not close when pressed by hand?-$75au genuine seal. Is it possible to replace this seal with out removing the crankshaft? Should i be using a sump gasket?-there wasnt one there upon removal. 86 series3
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
KarimPA
Sep 3, 2015 07:32 PM
d a
Sep 3, 2015 02:34 AM
