84 XJ6 Timing Chain Question
Old Sep 27, 2011 | 04:39 PM
Benhamtroll's Avatar
Default 84 XJ6 Timing Chain Question
The head removal continues apace, and I am finally getting close to trying to get the !$%#$&^ thing off the block. I have the cam covers off, and I'm getting ready to slacken the timing chain to disconnect the sprockets.
I loosened the nut on the serrated plate, and was able to get the pin depressed to be flush with the plate with a couple whacks. I can't get the plate to turn, however. Am I going to need the tensioning tool at this point as well as later when I retighten the chain? If so, where is a good place to pick one up.
Thanks!
Old Sep 28, 2011 | 04:15 PM
Fraser Mitchell's Avatar
Most Jaguar specialists should have the adjuster tools, they don't cost much. If you can't move the disc, take the nut off and try tapping lightly with a small hammer. The adjuster will seize up after the car has been standing for many years; it had on a 2.4 Mark 2 I rebuilt in the 80s.
Old Sep 28, 2011 | 04:18 PM
Look on this page
SNG Barratt - UK | Accessories
Use some dismantling fluid, or WD40 as well.
Old Sep 28, 2011 | 05:35 PM
I made this one, and I was able to get the wheel to start to turn. It got tight after less than a 1/4 turn, and then the center nut in my DIY tool started turning in the washer assembly.
I'll hose it down with WD-40 and see what happens.
Thanks!
Chris
Old Sep 28, 2011 | 05:49 PM
Never mind! I expected the chain to get a lot looser. It looks like I got it!
xjrjag
May 21, 2026 09:05 PM
celticpiping
Sep 18, 2015 06:17 PM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
