85 XJ6 Ignition switch replacement
Old Jul 26, 2010 | 11:00 AM
Executivekev's Avatar
Default 85 XJ6 Ignition switch replacement
Hello
My key in the ignition switch turns all the way around and will not start, if I push the electrical part of the switch the car starts. Obvoiusly its the switch, can the electrical portion be purchased seperately or do I have to buy the key cylinder and switch assembly.
Old Jul 26, 2010 | 12:50 PM
Doug's Avatar
Electrical part available separately, yes
Old Jul 27, 2010 | 07:22 AM
Default Jaguar ignition switch
Do I need any special tools to replace ignition switch electrical part, and do I need to remove the ignition cylinder, thanks.
Old Jul 27, 2010 | 08:19 AM
Doug's Avatar
The only remotely special tool would be a tiny phillips screwdrver for the little screw that holds the electrical part of the switch into the the key part.
It's an easy job.
Old Jul 28, 2010 | 08:01 AM
Thanks Doug
1100me
Aug 27, 2020 11:37 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
BigD
Aug 31, 2015 06:13 AM
kesslari
Aug 31, 2015 04:53 AM
roumor
Aug 28, 2015 01:02 PM
