85 XJ6 sunroof stack
Old May 9, 2021 | 06:43 PM
mikega's Avatar
Default 85 XJ6 series 3 sunroof stack
I opened the sunroof of my series 3 and it has refused to closed.
what's wrong and how do it fix it?
Old May 9, 2021 | 07:17 PM
Jose's Avatar
you need the emergency crank tool to close it manually.
Old May 10, 2021 | 06:16 PM
iramphal's Avatar
My sunroof opens and closes just fine, but I do not have the emergency crank. Anyone out there have a spare? I'm in Niagara Falls - on the Canadian side! Ian
Old May 10, 2021 | 07:15 PM
Doug's Avatar
Does the motor operate when you push the button? Does it seem like the sunroof is trying to close but is jammed?
If you have the little hand crank, try that.
If not, remove the rear seat and you'll see the cable drive mechanism. By removing a couple bolts ....they'll be obvious....you can remove the drive from the motor and slide the sunroof closed. Unless, of course, it is jammed on its tracks.
Old May 10, 2021 | 07:26 PM
Jose's Avatar
You can see them in my website:
https://jagupgrades.webstarts.com
Old May 11, 2021 | 12:25 PM
JagCad's Avatar
Jose:
Slick.
I have tried to open the link top your site before with no luck.
it worked this time.
Saved to favorites!!!
thanks.
kingtutt
Apr 15, 2016 06:19 AM
kingtutt
Apr 14, 2016 06:08 PM
Elbartus
May 28, 2012 03:33 AM
Joelewisfl
Sep 22, 2010 04:37 PM
