86 jaguar xj6 wont start please help
Old Sep 12, 2008 | 09:44 PM
Jose's Avatar
Default RE: 86 jaguar xj6 wont start please help
sounds like you know the car pretty well.
1) put the shifter in 1 and crank the ignition switch listening with your right ear towards the rear of the car to hear the fuel pump whirring as long as you keep the ignition switch in the
cranking position.(but obviously the pump must be pumping because you have 35psi at the Fuel Regulator).
2) check the Cold Start Injector, (CSI), it will stop the engine from starting. Best Test is to remove it and with someone cranking the engine, see if fuel jets out as you hold the CSI away from the face. (warning: the gasket will tear when you pull the CSI from its seat, better have a spare in advance of this test).
Jose
Old Sep 13, 2008 | 04:37 PM
Jose's Avatar
does not seem to be fuel-related then. If the injectors are clicking then the diode pack is good.
Then it looks like ignition or sensors.The ignition AMP is suspect. It is a GM part which can be found at NAPA. Check the wire connections at the AMP. Check the coil-to-cap HT cable. Check the wire connections at the coil.
study the following No-Start Troubleshooters:
http://www.jag-lovers.org/xjlovers/xjfaq/nostarts3.htm
http://www.jagbits.com/nostart.html
http://www.jag-lovers.org/xjlovers/x...lpumpcheck.htm
http://www.jag-lovers.org/neal03.html
Jose
1100me
Aug 27, 2020 11:37 PM
jdzubas
Oct 4, 2015 09:14 AM
97xj6lucy
Sep 3, 2015 07:44 AM
1964Daimler
Sep 2, 2015 11:41 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
