'86 Master Cylinder/Booster Gaskets
Old Oct 26, 2013 | 10:40 PM
Wascator's Avatar
Default '86 Master Cylinder/Booster Gaskets
Hi, I am replacing a failed/corroded master cylinder and brake booster. I need the square gasket between the booster and cast aluminum bracket, and can't find it. Is it OK to cut it out of gasket paper and go for it?
Ha: the booster I bought was perfect, only it was not painted at all. That's what I've been doing this weekend: painting it instead of installing it. Also the master cylinder.
Old Oct 27, 2013 | 07:00 AM
aussie_ser3's Avatar
Any gasket would be fine but to be honest you really wouldn't really see any ill effects if you left it out. You could also use some RTV sealer. There are plenty of cars that don't use any gasket at all
Regards
Jay
Old Oct 27, 2013 | 04:28 PM
Fraser Mitchell's Avatar
When I was working on cars as a poor man, you could buy gasket material to make your own, but I did this a very long time ago. But it seems the stuff is still around !
Gasket Material | AutoZone.com
X308XJR
May 20, 2019 06:50 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
baskervillema
Oct 1, 2015 01:59 AM
mrplow58
Sep 30, 2015 08:56 AM
