88 XJ6 ignition problem
Old Jan 19, 2014 | 01:30 PM
inoita11's Avatar
Default 88 XJ6 ignition problem
I bought an '88 XJ6 for 450 dollars thinking that the fuel pump had gone bad. All the symptoms pointed to that and so I replaced it. Worked fine for a while and thought I had found the problem. A little later it wouldn't start for anything and I found I had no spark. I was jiggling the ignition coil and then it fired back up again and ran fine. Left the lights on once and the battery died and when I jumped it I had nothing again. Finally for no reason it came back to life and ran fine again. It did it a 3rd time where I jiggled around the coil and the plug that goes to the ignition amplifier and it came back to life and ran fine even after stopping and starting it.
Now its back to the point where it won't run again. I've got good connection to the coil, good ground there. I can't figure out whats wrong with it.
Any suggestions on what it could be?
Old Jan 19, 2014 | 04:27 PM
Fraser Mitchell's Avatar
Try posting this in the XJ40 forum, the one for your car, you should get a better response.
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
laserguy
Sep 3, 2015 02:02 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
