89 jaguar timing i need help
Guest
Posts: n/a
i have an 89 jaguar vandenplaz i changed the head gasket i need help with the timing i thought i had it timed but it just pops in the intake well trying to start like its wrong
and it sounds like it has little compression help!!!! please
Guest
Posts: n/a
Thats not very sound advise, if the cam timing is off you will have low compresson just from that. Although you can do a leak-down test as long as the valves are closed. Your ignition or cam timing is def off, sorry I dont have the procedure in front of me but if the ignition is off and not the cam then you need to retard it.
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
