The Base of the Seatback
Old Jan 11, 2023 | 10:43 PM
adenshillito's Avatar
Default The Base of the Seatback
remade the seat backings (which is actually rather fun) but the brace-bracket that links into the seat body doesn't seem right, doesnt sit level and leaves a gap up the side of the seat so the plugs don't reach the frame. what am i missing in the scheme of things? is something old or bent in some way, well i guess it cant be as the same issue on both sides.sure i dont have this issue last time. any thoughts?
shouldnt the adjuster thing sit exactly in he centre of the round cut out on the brace and not pinned to the top edge of the circle?
this looks ok i am guessing...
Old Jan 12, 2023 | 03:06 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
The top of the seat back card slides up under the upholstery at the top of the seat. The frame is designed for it, you just have to look closely. When you have it positioned correctly, everything will line up.
Dave
Old Jan 12, 2023 | 03:24 AM
the back is seated up under the ridge as you suggest, the brace at the bottom on each seat in the centre by the console appears correct but the outer seat brackets on each side do not. i wondered if the shape of the timber back had been lost over time in reproduction. seems odd.
Old Jan 12, 2023 | 03:27 AM
LT1 jaguar's Avatar
Sorry, my only experience is with the S3, your S2 may be different.
Dave
Adz3000
Aug 12, 2025 10:13 PM
iramphal
Dec 19, 2022 05:56 PM
Johnken
Aug 9, 2021 03:59 PM
nitro28
Sep 11, 2020 03:03 PM
volkris
Oct 31, 2019 03:35 PM
