Broken differential breather
Old Nov 25, 2013 | 03:35 PM
vpjag's Avatar
Default Broken differential breather
Just finishing up the rebuild on my IRS unit and noticed that I managed to break the breather off of the differential. Guess I wasn't careful enough while wrestling that beast around! The elbow snapped off flush with the housing. My searches show a replacement part #JML631 and #8501 for the elbow, but I am having trouble tracking them down. I am assuming that this breather must be important or it wouldn't be there..otherwise I would plug it. Does it really build up that much pressure??? I'm sure that others have dealt with this little breather unit... what else did you do? Where did you find it?...or how did you modify it? Advice is always appreciated! Thanx in advance.
Old Nov 25, 2013 | 03:47 PM
plums's Avatar
The breather is important. A clogged breather causes lubricant to be pushed out the seals. So, plugging it is not a good idea.
The breather for the X300 (1995-1997) differentials is definitely still available. Pictures of those can be found in the X300 section. It is a capped elbow with a snap-ring retainer on the inside of the differential. Is your differential the same?
Old Nov 25, 2013 | 04:52 PM
icsamerica's Avatar
Default ebay
The differential breather and elbow are both available on ebay. Seach for "jaguar differential breather"
Old Nov 26, 2013 | 11:25 AM
vpjag's Avatar
The elbow on mine just threads into the differential housing...but I have found one. Thanks guys!!
MrWhite
33
Oct 22, 2015 10:29 AM
adam699
Oct 13, 2015 05:53 PM
NathanDD6
Oct 6, 2015 11:20 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
