A:C Blower - makes a racket!
Old Mar 28, 2026 | 04:38 PM
Jnscott96's Avatar
Default A:C Blower - makes a racket!
Hello
having an issue with A/C fan on 1987 XJ-6. When the fan is on past the lowest speed, it makes a ton of noise. Repair person told me it needs to be replaced but cannot find the part.
any ideas?
Old Mar 28, 2026 | 06:33 PM
slofut's Avatar
Probably leaves in the fan, pretty simple to drop the fan, clean out the leaves and don't park outside under the trees.
Old Mar 28, 2026 | 07:56 PM
Jnscott96's Avatar
unfortunately I’m sure it’s not leaves making the noise - we did inspect it. A/C is blowing cold, thank goodness.
Old Mar 29, 2026 | 09:37 AM
Jose's Avatar
inside the fan blower case under the dash, there are plastic pins that hold metal rods together. These rods open or close the fresh air or recirculate flaps.
The plastic pins deteriorate and break causing the rods to flop all over inside the fan case.
Removing the blower case is a mother of a job, use the Shop Manual and follow the steps.
Old Mar 29, 2026 | 10:35 AM
yachtmanbuttson's Avatar
If it's bearings they can be oiled. Unfortunately it requires removing the fan which isn't easy, but not impossible. I've done it with success.
Asdrewq
Aug 13, 2025 05:16 AM
badicedog
Sep 24, 2021 07:32 PM
SS4PK
Jun 19, 2019 08:29 PM
GoNavyMike
Nov 16, 2015 12:34 PM
