Doug
close
- Join DateMar 2008
- LocationPacific Northwest USA
Liked:11,721 Times in 7,586 Posts
Agreed on bellows leaking. If not torn, sometimes the edges have curled up a bit a no longer seal against the end plates. A bead of silicone sealer will fix that.
Don't forget to check the fuse and the vacuum supply hose
More reading, the XJS system is the same as yours.......
Cruise Control
Cruise Control
Jose
close
- Join DateMar 2007
- LocationFlorida
Liked:2,659 Times in 2,003 Posts
is the switch behind the Shifter set to ON when you press the turn signals stalk switch Button?
is the speed over 45 mph when you press the Button ?
JagCad
close
- Join DateJul 2012
- LocationWalnut Creek, California
Liked:2,403 Times in 1,883 Posts
More checks:
1. Cruise interrupt switch on brake pedal. Closed with pedal up. Open when brake applied.
2. Micro switch on shift tower. Open in P or D.
3. Cable from bellows to throttle pedal.
4. Double bullet connector in engine bay. Apply Jaguar mantra.
As for me, I rarely use CC. it isn't connected in my Jaguar
Carl.
Carl.
