Cruise control
Old May 8, 2015 | 07:17 AM
amaezing's Avatar
Default Cruise control
My cruise doesn't work. Is there a common problem with these (1985 Vanden plas) that I can start with?
Old May 8, 2015 | 08:41 AM
Saemetric's Avatar
Most common is vacuum leak in bellows. Check it closely for tear.
Old May 8, 2015 | 08:46 AM
Doug's Avatar
Agreed on bellows leaking. If not torn, sometimes the edges have curled up a bit a no longer seal against the end plates. A bead of silicone sealer will fix that.
Don't forget to check the fuse and the vacuum supply hose
More reading, the XJS system is the same as yours.......
Cruise Control
Old May 8, 2015 | 09:36 AM
Jose's Avatar
is the switch behind the Shifter set to ON when you press the turn signals stalk switch Button?
is the speed over 45 mph when you press the Button ?
Old May 8, 2015 | 11:02 AM
JagCad's Avatar
More checks:
1. Cruise interrupt switch on brake pedal. Closed with pedal up. Open when brake applied.
2. Micro switch on shift tower. Open in P or D.
3. Cable from bellows to throttle pedal.
4. Double bullet connector in engine bay. Apply Jaguar mantra.
As for me, I rarely use CC. it isn't connected in my Jaguar
Carl.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
