Dash Gauges
Old Apr 21, 2016 | 04:25 AM
adenshillito's Avatar
Default Dash Gauges
Most operate at start up but usually with a few minutes all dead. Sound like heat getting to them at some point after engine warms up? Or what else might cause.?
Old Apr 21, 2016 | 04:55 AM
yarpos's Avatar
Dont know if its the same in an S2, but in an S3 the dash gauges share a common fuse (no4 in main panel). Mine started developing the wanders and have improved after a clean. Might be worth giving then a clean up.
Old Apr 21, 2016 | 05:29 AM
Memory, hahaha.
Up above the Tacho??? is an instrument stabiliser, and they are Lucas, and do fail.
Easiest way is to remove the dash top and reach in.
Option 2, push the tacho IN and rotate counterclockwise?, and pull out, then reach in and see what gives.
Its been a while, but all my S2's had issues like that and it ws that stabiliser and/or wiring connections, and good old bad earths.
Old Apr 21, 2016 | 09:50 AM
frostee's Avatar
I had a similar issue to this, where my battery gauge would start then just completely stop. My issue was the connection on the back wasn't on properly, looked like it may have been tampered with.
But anyways, best of luck and let us know your findings!
Old Apr 22, 2016 | 03:39 PM
Hardly science as I couldn't fix out exactly what was what in that tiny space, but a clean out behind the dash with the gauges out seems to have fixed all the gauges at once. Not sure what I did however.
Old Apr 22, 2016 | 03:51 PM
looking through front window behind the dash board with dash surface off.
jahummer
Jun 16, 2016 02:35 PM
Greg in France
May 17, 2016 12:12 AM
orangeblossom
Apr 27, 2016 01:39 AM
Noah
Apr 23, 2016 12:11 AM
SJWwalt
XF (X260)
Apr 21, 2016 07:22 PM
