Dashboard bulb replacement
Old May 23, 2014 | 02:28 AM
e21pilot's Avatar
Default Dashboard bulb replacement
I still have the bottom of the dash off after replacing the wiper switch and wondered if access from the bottom was the best way to replace all the dash bulbs behind the six instruments?
Any other bulbs easily accessible from under the dash while I'm at it?
Old May 23, 2014 | 07:49 AM
Doug's Avatar
If you can get your hand up there to do it then that's the best way
If you can't then remove the speedo and tach. You'll then be able to reach those bulbs easily plus you'll now have two nice access holes to reach the others thru.
To remove the speedo and tach push them in firmly with your fingertips and turn counter-clockwise* about 45º. You need to push pretty hard on the rim of the instrument. Sometimes it helps to remove the cover for the center warning light cluster....it just pops off.
Nope!
*Clockwise if you have a RHD drive car, by the way
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 3, 2015 07:32 PM
XFR_Gold
Sep 2, 2015 12:24 PM
