Differential ratio
Old May 18, 2023 | 06:15 AM
Freddie1's Avatar
Default Differential ratio
Hi all
series 2 XJ 1978.
does anyone know if the differential is the same on both 6 & 12 cylinder cars please?
Old May 18, 2023 | 07:14 AM
Doug's Avatar
I don't know. Diff ratio often varied with market.
In that era 3.07 and 3.31 were commonly used by Jaguar. I think North American market cars (both 6 and 12 cylinder) usually got the 3.31 and other markets the 3.07.
A V12 car would have LSD as standard; optional on 6-cylinder cars.
Others will chime in
Old May 18, 2023 | 10:20 AM
Mine, 6-banger originally, is 3:31.
Old May 19, 2023 | 01:24 PM
Darrenmb's Avatar
Veteran: Navy
If you can’t find what you need, ( which I couldn’t) you can take pumpkin to a reputable 4x4 shop and they can put whatever gears you like in it, and add limited slip, mines now an auburn limited slip with 3:73 gears, really helps get the car moving off the line!!
Old May 22, 2023 | 06:31 AM
lickahotskillet's Avatar
Default Gears
My ‘77 twelve cylinder was 3.31. It’s now a 3.54 from Coventry West.
Transmission also makes a difference. I have a special built close ratio 700R4 with different first & second gears. First is 2.78.
Old May 22, 2023 | 07:25 AM
All my S2 cars were:
V12 = 3.31 LSD
6cyl = 3.07 Open.
I believe OZ got the same spec as UK.
Old May 22, 2023 | 08:26 AM
Freddie1's Avatar
Thanks guys. I’m clear on this now. Many thanks
Freddie1
May 18, 2023 05:44 AM
Fastcat
Jan 3, 2022 03:43 AM
AnttiM
May 14, 2018 04:09 AM
Roger Mabry
Jul 7, 2015 10:35 PM
Jose
Jul 30, 2007 08:44 PM
