Dim dash lights
Old Oct 22, 2019 | 04:25 PM
worzella's Avatar
Default Dim dash lights
Drove my 86 XJ6 for first time in dark. Dials were hardly lit. I thought well I will just rotate knob to raise level. It was all the way up!!
Are these dash dial lights notoriously dim or another todo to add to my fix list? 😁
If a problem any suggestions? No burned out bulbs just very dim
Thanks. Randy
Old Oct 22, 2019 | 06:32 PM
Jose's Avatar
they are always like that.
if you replace the bulbs with higher wattage bulbs, they will burn the plastic color lenses inside the gauge Typical mistake.
some owners bypass the Dimmer rheostat but you gain little brightness.
some use LEDs and supposedly fixes the problem but creates other problems such as having to use relays.
Old Oct 22, 2019 | 07:25 PM
worzella's Avatar
Ha ha - Love it.... Thanks Jose!!
Old Oct 22, 2019 | 07:51 PM
Doug's Avatar
I've had good luck bypassing the resistor.
On my present car I jumped on the bandwagon and went to LED bulbs. But it wasn't easy. The six instruments require three different bulbs. No problem finding LEDs to fit. The problem was getting the brightness to match on all the instruments . I found a mismatch to be very annoying.
Eventually, with the help of a fellow poster, I found the right combination of LED bulbs. It required changing the socket on the speedo or the tach....I can't remember which. All's well that ends well but I was just about ready to throw in the towel and go back to the standard bulbs.
If you're interested I can try find the thread that covers the details
Old Oct 23, 2019 | 05:14 AM
iramphal's Avatar
Doug, I'd love to try the LED route as an "overwinter" project. If you ever find those details, I would take the plunge. Ian
Old Oct 24, 2019 | 10:28 AM
JagCad's Avatar
Oh me. Mine are "lights out".. Jump the rheostat? last year, aye. Today, no matter, not likely to drive it at night. And, if I do, a small flash light in driver door pocket...
Carl
Old Oct 24, 2019 | 04:06 PM
Jose's Avatar
ask me about the anemic WIPERS in my '84.
i replaced the wiper motor, no cigar. I still have the 1983 Vintage Collectible Collector's Item original wiper motor. The 1985 motor is as anemic as the original.
Enter my 1965 S type. Two speed Lucas wiper motor. Fast as any modern car. It actually copes with rain storms. The XJ ? forget it.
Old Oct 24, 2019 | 06:26 PM
worzella's Avatar
Thanks for the replies... this item is kind of low on my to-do list DD so I will see how Ian fairs (fares?) with his winter project. I am sure he will write up a step-by-step procedure for us all to use - ha ha.
I get a free weekend with good weather and have so many little projects planned. Half the fun of owning an old car is cleaning it up and fixin' stuff !!
Oh, by the way, my trip compute appears to be toast. Not a flicker of life. I need to do a serious fuse check and someone I thought said there was a "reset" procedure.
Also, my 15 year old daughter was so psyched there was an old cassette player in the car. Until we fed it a tape and it ate it and... nothing. The radio doesn't do much and the lights on the unit just kind of randomly flicker on and off. But the antenna grinds its way up and down -
Randy
Old Oct 24, 2019 | 07:44 PM
Doug's Avatar
See posts #3 and #12 in this thread
https://www.jaguarforums.com/forum/x...s-pics-191007/
I ended up with these for the smaller gauges
https://www.ebay.com/itm/182544151604
And these for the tach and speedo
https://www.amazon.com/gp/product/B079KPD2P1/ref=od_aui_detailpages00?ie=UTF8&psc=1&tag=viglink 21907-20
Old Oct 26, 2019 | 11:14 AM
JagCad's Avatar
Randy:
I guess I am fortunate. The radio and player in my 83 work decently. Some casettes uust fail. A glue joint of the tape parts. " I have some really old ones. The
play OK in either the Jaguar of my 94 Jeep.
OTH old 8 tracks are worse and rarely survive... I've a bunch of 'em!! Two decks to run them, not hooked up anywhere..
Carl
obwoodie
Jan 8, 2016 10:41 PM
rick.hall
Dec 14, 2015 06:34 PM
