Distributor Shaft Bushing
Old Jan 4, 2017 | 08:44 PM
Being a S3, access wil be fun.
I prime the oil galley via the oil switch hole with a large syringe filled with oil.
It will prime the main gallery, oil pump, and the crankshaft.
It MAY push some to the top end, but doubtful, so I usually assembly lube the cams prior to covers on.
Also liberally coat the chains and guides with assemby lube.
I also set the tappets prior to intalling the head, it is just easier.
