dry sump ajv8
Old Jan 23, 2016 | 06:24 PM
Stevecosta's Avatar
Default dry sump ajv8
Gday ladies and gent I'm in the process of putting an AJV8 engine into a s3 Sovereign but it looks like im going to need a dry sump kit for clearance reasons can any body point me in the direction of one?
Old Jan 24, 2016 | 09:03 AM
icsamerica's Avatar
That's quite ambitious. But why? Nothing special about an AJV8. Not particularly reliable or powerful and a mountain of serious technical problems await you. A better Jaguar choice is the AJ6 / AJ16 and their derivatives.
Old Jan 25, 2016 | 02:07 PM
Stevecosta's Avatar
I haven't heard of any major issues with the AJV8 series of engine (other than the 4L) I have a 2005 4.2L.
Cant be that bad of an engine its been used across many models internationally and has masses of potential.
What issues are you aware of?
Old Jan 25, 2016 | 07:41 PM
thedugger1's Avatar
The only issues I was aware of with the AJV8 were:
Nikasil Cylinder liners caused by high sulphur fuels.
Water Pump impellers
Plastic timing gear failure
Throttle Body issues
I don't think the first is an issue any longer, at least in the US with lower sulfur fuels. The latter three are relatively easily dealt with. Perhaps I was just lucky, but the 99 XJ8 I had was one of the most trouble free cars I ever owned!
As for the ease of a swap or dry sump, I don't have a clue!!
Old Jan 26, 2016 | 11:05 AM
JagCad's Avatar
Sump issues have been dealt with in the past and recent time sans going to dry sump. Dry sump isn't really dry, merely a smaller sump.
What is the issue? Front deep part fails to clear the cross member?
Classic issue in other critters from way back. Dealt with then
and can still be done.
Move the pick up and adapt the sump, (pan) in USA speak. Easier in tin, but quite doable in alloy....
Carl
Old Jan 26, 2016 | 02:37 PM
ronbros's Avatar
dry sump is alot of modifications, and expensive parts!
are you sure you need to go that route?
but if so, Summit/Jegs have many components, to put together a setup.
but seems someone on this site is familier with D/S for AJ8, check 550hp in engines&transmissions! Iblis
Old Jan 27, 2016 | 10:05 PM
Stevecosta's Avatar
Dry sump was just an option I was looking into.
Yeah front fails to clear cross member.
I've also tried a range rover sump but that fails to clear the rack and pinion.
now considering modifying the cross member and sump...
avos
380
Dec 14, 2016 12:14 AM
philwarner
Jan 18, 2016 11:42 AM
avos
Apr 11, 2011 02:07 AM
avos
Sep 12, 2010 06:45 PM
