excessive fuel consumtion
Old Jan 16, 2008 | 04:31 PM
H20boy's Avatar
Default RE: excessive fuel consumtion
Ouch, that's more fuel I believe than the car can actually burn, even a 12 cyl...gotta have a hole in gas tank!
I hope you were truly exaggerating about your fuel mileage.
Old Jan 16, 2008 | 04:37 PM
ken@britishparts.com's Avatar
Must have huge plumes of smoke behind you to run that rich. Check for leaks.
Old Jan 18, 2008 | 10:34 AM
skanoski's Avatar
If you're gas tank is leaking, you would probably see it when you're parked. It's probably a leak in your fuel lines somewhere. Check the connections at the fuel filter to start.
I guess my 12mpg could be worse, eh?
Old Jan 18, 2008 | 11:11 AM
12 mpg would be normal for a v12. I read it as a gallon a mile.
Old Jan 20, 2008 | 11:22 AM
FactoryJaguarTech's Avatar
Ummmm as Ken said, Look for leaking at fuel lines, especially up at engine. Horror stories could be told of V12's catching fire.
Seth
Nov 1, 2015 12:17 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
BSM
Sep 25, 2015 05:00 PM
reb1999
Sep 25, 2015 10:00 AM
