Five pin headlight relay...
Old Jun 2, 2013 | 05:10 PM
marvin1960's Avatar
Talking Five pin headlight relay...
Are all five pin headlight relays created equal? Will a new 30 amp five pin headlight relay for a mid 80s american car work as a replacement for the 87 xj6 five in headlight relay?
Old Jun 2, 2013 | 05:26 PM
Doug's Avatar
Not all created equal by any means. Many variations.
In the case of your headlight relay it has a "latching" feature that allows the high beams to stay on once the relay has been activated. This is required because the high beam/column stalk lever itself does not latch into position.
There might well be a good substitute out there somewhere but I don't have any info.
The headlight relay can be opened up to clean the contacts. This usually brings 'em back to life. However, if the plastic latch is melted, you're sunk
Old Aug 13, 2013 | 05:46 PM
Padrino's Avatar
My relay just fried itself. Anyone have any luck on finding a good substitute for the OEM which is priced at around $150....if you can find one?????
Old Aug 13, 2013 | 06:10 PM
WhiteXKR's Avatar
....never mind...
Old Aug 13, 2013 | 06:49 PM
Doug's Avatar
Get a good used one, open it up, clean the contacts....it'll probably last for years.
As far as I know there are two common causes for failure:
1) Dirty contacts = high resistance = heat = failure
2) Holding the "pull back for headlight flash" too long which overheats the plastic latch
Old Aug 14, 2013 | 08:51 AM
Padrino's Avatar
I believe I was guilty of the latter, number 2. I can recall the #%^]#!! Idiot in the fast lane going 55!!!
Old Aug 14, 2013 | 10:05 AM
Doug's Avatar
I see similar idiots almost every day on my daily commute. Why so many people disregard proper lane usage is beyond me.
At some point they usually realize they're in the wrong lane and, to let faster drivers continue on, decide to move to the right. This lane change always seems to occur six feet in front of ME!
Now MY peaceful, relaxed, and well-spaced progress is all bollixed up !
Grrrrr.
Old Aug 14, 2013 | 10:17 AM
JagCad's Avatar
Check with David Boger at everydayxj for a good used unit or a new old stock. Good guy. posts here from time to time and elsewhere..
Old Aug 14, 2013 | 10:29 AM
Padrino's Avatar
Update on the price...if one is available!! $185.00 plus shipping. OUCH! Someone's gotta have a $3 substitute idea....please!!!
Old Aug 14, 2013 | 02:25 PM
JagCad's Avatar
Read my post as to David Boger. probably mnore than three bucks, but a hlll of a lot less than 185++
Old Aug 15, 2013 | 08:46 AM
Padrino's Avatar
Default Modification to the headlight relay system?
Today I pick up my new $200 headlight relay. OUCH! I don't want to go thru this again so I've been doing some research into how to prevent that. In my research I've found also that the headlight dimmer switch (turn signal) is carrying the full load of the 'low beam' headlights. I don't want to guess how much that baby costs!
I found an article by a guy who 'bypassed' the dimmer switch by adding another ($3.00) relay to that circuit ( RELAYS-2 ). I decided before I put in the new and expensive relay I'm going to add the relay as he's suggested PLUS one more $3.00 relay to also pick up the load off the expensive relay to power the high beams too.
The diagram he used for the added relay to relieve the dimmer switch is as follows:
Simple enough to add the one relay on the left for this purpose. I'll also throw one on the high beam circuit and relieve the load on the main relay. Its purpose now will only be to activate the second relay and if I have to replace anything again, it will be the $3.00 relays.
Will report back on the success but it seems (on paper anyway) that it'll work.
Old Aug 15, 2013 | 09:04 AM
Doug's Avatar
Well, no, actually it isn't.
The dipper switch (column stalk that you pull rearwards) only does one thing: closes a ground circuit to energize the headlight relay.
Supply voltage for the low beams goes thru the headlight switch and then thru the relay. Note "thru the relay" and not "provided by the relay"
However......
Adding the relays is a good idea (or at least a "can't hurt" idea) because the load of the low beam lights is carried by the headlight switch itself (perhaps that's what you meant to say?)
Some guys also increase wiring size to the headlights. This, with the added relays, can improve headlight brightness....especially if the old connections were weak.
OTOH, some will say....and they're not entirely wrong, mind you.....that a circuit/switch/relay design that lasts 25 years before needing attention isn't particularly sub-par.
Old Aug 15, 2013 | 11:09 AM
Padrino's Avatar
You're correct Doug, the 'dip switch' only activates the relay and the full light load comes off the switch. The guy's article I referenced had it wrong. I checked 3 wiring schematic sources.
Now to install the 2 new 40 amp relays to take the load off the switch and if I've figured it correctly, off the main relay ALSO. Although it's been working correctly since 1987, and I do have the 'British' version to allow the fog lights to operate separately, I want to put as much of the load off on some $3 parts in lieu of the expensive stuff.
More later.
Old Aug 18, 2013 | 05:38 PM
Sean W's Avatar
Default Replacement relay
Sorry I'm late to the party but there is a cheaper replacement out there BWD
R3018. About $35.
Old Aug 18, 2013 | 05:58 PM
Doug's Avatar
R3018. About $35.
Great find!
Old Aug 20, 2013 | 03:13 PM
Padrino's Avatar
Default Brighter Dash Lights
I've been trying to find the time to write in detail but that isn't happening and I had to put this out there.
My Jag mechanic couldn't source an original headlight relay so he's been using a Volvo one. About half the price at a bit over $100. I put it in but I ALSO wired in the 2 spst $7.00 40 amp relays to pick the load off the main headlight relay so not to risk burning it out again. (next time I'll include that diagram and info on the Volvo relay).
The interesting part is (besides it all works which even amazed me ), is that my dashboard and shift indicator lights are now brighter. I'd bypassed the rheostat before so that doesn't come into play. Just simply, the dash lights are now a bit brighter which is truly enjoyable.
WTF???
Old Aug 22, 2013 | 09:15 AM
Padrino's Avatar
Default Double 40 Amp Relays Added, Schematic and Alt Main Relay
Found some time to input what I've done.
First was that my Jag mech couldn't source another new stock relay and said he'd been referenced to using a Volvo relay with a "bridge" connector added. I've included a photo of this relay, the info and a pic showing the white 'bridge' wire. Seems to work as I connected it up before my adding my 2 relays to the circuit.
The intent of the added 2 relays was 1.) pick up 'some' of the load off the main headlight switch and 2.) pick up the highbeam load off the main relay. I've added 7" headlights (which are GREAT) so the load is more. Figure my original relay burned out due in part to that load. I found that to get the 'latching' of the main relay to work, I needed to leave the lowbeam circuit intact but with the added relay and wiring to it I seemed to have picked up at least part of the amp load off the main (and expensive) relay.
I couldn't be more pleased. Other than the figuring the circuits out and some trial and error (more error than trial by the way) it took me about 30 minutes of making the connector wiring and installing. Total cost without the new 'main relay' was only about $20.
My wiring included just making short jumpers with 10 and 12 ga wires so as to easily work everything in. The 40 amp relays were only about $7 each so I figured it would be cheaper to replace these than the main relay...if I got it all to work, which I did. I couldn't be happier with this cheap modification. Excuse the poorly drawn schematic wiring diagram.
Pics and info are attached. Somehow, it all works and my interior dash lamps are much brighter out of all this.
Attached Thumbnails Five pin headlight relay...-487.jpg   Five pin headlight relay...-488.jpg   Five pin headlight relay...-486.jpg   Five pin headlight relay...-xj6-headlight-relay-modified-scheme-2-added-relays.jpg
Old Aug 22, 2013 | 09:24 AM
Padrino's Avatar
Default Electric Relay Schematics
I realize I should have also included the 'stock' headlight schematic so the changes would be more evident and easier to understand. Posted are both the stock and the modified ones:
Attached Thumbnails Five pin headlight relay...-xj6-headlight-relay-stock-scheme.jpg   Five pin headlight relay...-xj6-headlight-relay-modified-scheme-2-added-relays.jpg
Old Mar 10, 2015 | 06:48 AM
JagLoverT's Avatar
Default Replacement Worked
R3018. About $35.
Sean - Thanks for the low cost replacement it is working fine. I want to share my trials with the replacement; This relay is not as robust as the Hella relay and in an attempt to mount the relay with the clip on the BWD R3018, I took the cover off and bent the clip outward so I could run a screw throught it for mounting. In the process I slightly bent the internal latching mechanism and they wouldn't dip until it was corrected. If I need replacement relay in future I will try Padrino's suggestion that has an affordable price ($39 from volvo dealer online) It is a volvo headlight relay and looks very similar to the original Hella Headlight relay part information is Volvo 130799.
Thanks Sean and Padrino
Old Feb 24, 2016 | 12:38 AM
yarpos's Avatar
The number for the generic latching relay is DNI0127 (=BWD R3018). This is really just a place note to myself, I have to come back and do this job soon.
