Foot Pedal
Old Jun 10, 2024 | 11:36 PM
adenshillito's Avatar
Default Foot Pedal
Now in simple terms and given its awkward position how does one put this back together
correctly....?
Old Jun 12, 2024 | 02:15 PM
slofut's Avatar
Not seeing a pic?
Old Jun 12, 2024 | 10:13 PM
curious. i can see it. gas pedal.
Old Jun 13, 2024 | 08:30 AM
Yes, it IS awkward!
I found it best to set the top properly first, and then set the screws wherever the holes in the bottom fall.
You might need to drill new holes, for example if you put in a new floor pan.
Old Jun 13, 2024 | 10:19 PM
Jeffkrell's Avatar
Is that thing hinged or is it tied to sheet metal and bends the metal back and forth ?
Old Jun 14, 2024 | 08:01 AM
slofut's Avatar
The plastic pedal is hinged at the bottom and screws to the floor with two screw. The top bracket thingy slides along the accelerator lever to keep the plastic centered and in place.
I can see the pic now...
Lambretta
Sep 8, 2019 06:22 PM
Curless Auto
May 23, 2017 05:43 PM
DB6
Jun 21, 2011 11:21 AM
