Front spring packer dimensions
Old Aug 26, 2015 | 10:29 AM
Mr.B's Avatar
Default Front spring packer dimensions
I need to add a packer to the front springs to raise my ride height a bit. I have some 3mm nylon sheet that would work, does anyone have the dimensions of the standard spacer ring used by Jaguar? If I add a single 3mm packer, how much ride height would I gain?
Is there any way to get the packing piece in position without having to completely remove the spring? I'm familiar with both the threaded rod in the spring pan bolt holes and the giant threaded rod in the middle of the spring methods of removing the spring but would like to avoid them if at all possible.
Old Aug 26, 2015 | 01:49 PM
plums's Avatar
first go to
everydayxj.com
and see what David has.
Old Aug 27, 2015 | 10:06 AM
Mr.B's Avatar
Originally Posted by plums
first go to
everydayxj.com
From what I can see there, David doesn't have the dimensions of the packer or an alternative way to install it.
What have I missed?
Old Aug 27, 2015 | 06:09 PM
plums's Avatar
His items are mostly very inexpensive ... the idea was to not bother with homemade
and just buy them.
Old Aug 27, 2015 | 08:16 PM
Doug's Avatar
Took a bit of rummaging but I *knew* I had one of these stashed away !
O.D. = 6.125"
I.D. = 5.000"
Thickness = .125"
Each packer makes 3x difference in ride height as I recall. So, for example, 3 packers alters height by .375"
Old Aug 28, 2015 | 01:48 AM
Mr.B's Avatar
Originally Posted by Doug
O.D. = 6.125"
I.D. = 5.000"
Many thanks Doug, that's just the info I need. But did you mean to say 1 packer = .375"?
Old Aug 28, 2015 | 02:14 AM
Doug's Avatar
Oooops.
Yes, I did.
So, a single .125" packer makes a .375" difference in height
Thanks for catching that flub
bamforp
Aug 14, 2024 05:36 PM
ym37tech
Feb 8, 2016 01:04 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Tar
Sep 6, 2015 11:24 AM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
