Front Sub-frame removal
Old Jun 10, 2019 | 06:50 PM
Take a look at this post. It explains everything you're asking.
https://www.jaguarforums.com/forum/x...2/#post1246489
Old Jun 10, 2019 | 09:05 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Originally Posted by geodon
Excellent! Thank you! The factory workshop manual was not this helpful.
So No1 & 3 bolt the steering arm and caliper to the stub axle?
No2 attaches just the brackets for the pipe & dust shield?
Elinor's picture is accurate, but you described the bolt #/use a little off.
#1 secures the caliper and half the pipe bracket
#2 secures the upper steering arm, the other half of pipe bracket and top of disc shield.
#3 secures the lower steering arm and the bottom of the caliper.
I did one side at a time just so I could refer to the intact side when I couldn't figure something out. The front caliper/pipe bracket/disc shield kept me going back and forth for about half an hour, short term memory is not so good.
Don't forget the possible shim washer that was probably on bolt #3 between the steering arm and caliper.
Dave
Old Jun 10, 2019 | 11:54 PM
geodon's Avatar
Dave
Ah ha! The penny drops! The steering arm goes on at an angle (partially transverse) not vertical.
Thank you!
Old Jun 11, 2019 | 12:02 AM
Never mind.....
Paulc732
Sep 22, 2021 12:52 PM
rocklandjag
Nov 25, 2020 06:28 AM
scoobie
Oct 16, 2014 01:32 AM
vandenplas408
Feb 11, 2014 09:27 AM
henryj456
Oct 6, 2011 07:38 PM
