Fuel Sending Unit Brand Quality?
Old Sep 11, 2023 | 06:32 PM
MSGGrunt's Avatar
Default Fuel Sending Unit Brand Quality?
Other than OEM, is there a difference in quality with the various fuel sending units available for the Series 3 XJ6? Seems like a pretty simply device, but thought I would ask before buying.
Eurospares. Looks anodized.
Original Equipment, not to be confused with OEM
Moss Motors. No brand given.
SNG Barratt. No brand given, just aftermarket and needs to be custom bent.
Old Sep 12, 2023 | 07:58 PM
David84XJ6's Avatar
I went with Moss a RH and LH sender, came with new lock and seal... Went in without issue and read correctly within two needle widths.
Previously fussed with the bend to suit sender. After three attempts to get correct readings, gave up. If it was good on full tank, it was off on 0 to 1/4 tank.
Installed Moss units and ran tank down to last line before empty. Filled tank to see how many gallons needed until station fuel pump shut off. Then calculated both gallons and miles until empty.
Rgds
David
Old Sep 13, 2023 | 06:45 PM
Doug's Avatar
Over the years (decades, really) I've replaced a few on my own cars and others. They've all been slightly inaccurate, either a bit too high or too low. All aftermarket but I can't remember brands or vendors
FWIW
Old Sep 15, 2023 | 05:14 AM
MSGGrunt's Avatar
I ended up buying them on sale from Autohaus AZ for $41.99 each. The brand was Eurospare.
robroy
Jul 8, 2022 12:06 PM
RMA
Aug 26, 2019 07:34 AM
p-Rock
Feb 11, 2019 08:20 PM
Retro
Feb 22, 2012 12:10 PM
sneal46
Jul 26, 2010 10:41 AM
