Fuel system help
Old Apr 20, 2011 | 01:45 PM
dlpoling's Avatar
Default Fuel system help
Ok heres the deal Engine runs ok. but when I turn on the key, the fuel pump does not prime. When I crank the engine fuel pump operates as normal and starts after about 30 seconds the fuel pump relay appears to be fine but no voltage on the wire coming from the main relay to fuel pump relay. I beleave this is were the prime signal comes from. Ok ready to stand corrected....
Doug
Old Apr 20, 2011 | 02:20 PM
xjrguy's Avatar
Help us help you....... Year and model???
Old Apr 20, 2011 | 06:33 PM
dlpoling's Avatar
oopps sorry 85 xj6 series 3
Old Apr 20, 2011 | 08:33 PM
Doug's Avatar
Your model doesn't have a "prime" capability.
The fuel pump relay is triggered by voltage from:
A) the starter circuit to power the pump when cranking, as you've observed
B) a switch inside the air flow meter to power the pump when the engine is running
Voltage from either of these sources goes thru the red diode pack and triggers the fuel pump relay
The entire pump control circuit can be bypassed for diagnosed by removing the pump relay and applying 12v to the terminals in the socket that go to the white/green wires. You should hear the pump run. If the car starts and runs properly then you know you have a problem in the circuit. If the problem doesn't change, look elsewhere.
Do you have a fuel pressure gauge by the way? You might need one.
This might help for fuel pump circuit testing:
Fuel Pump Circuit Checklist
Since the car basically runs well I think you may have a problem not related to the fuel pump. Does the problem occur hot, cold, randomly, always?
Old Apr 20, 2011 | 08:41 PM
xjrguy's Avatar
Once again, Doug is quicker on the draw! He's got you covered.
Cheers,
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
ccfulton
Sep 20, 2015 05:15 PM
deanh
Sep 6, 2015 08:20 PM
AL NZ
Sep 4, 2015 08:39 PM
