Fuse#6 of xj12c
Old Feb 11, 2020 | 03:01 AM
mmac867's Avatar
Default Fuse#6 of xj12c
I have a 1975 xj12c.
I have a question about the fuse box.
Fuse #6 continued to short. So I cut one of the two green lines. Then the fuse stopped shorting.
According to the manual, there are many things that work with fuse #6. (I attach a picture of the fuse box and a manual.)What I haven't checked yet are battery cooling, screen washers, kick-down switches and solenoid valves.
Since my car has no battery cooling, I want to know how to check if the kick-down switch and the solenoid valve operate normally.and Is there anyone who can tell me about the green wire I cut?
Old Apr 29, 2020 | 08:07 AM
mmac867's Avatar
I solved this problem. The screen washer motor had an electrical problem because of the washer fluid. So I replaced the screen washer motor.
Jaesteban
Feb 10, 2020 09:00 AM
OUScooby
Dec 31, 2019 09:48 PM
baloozman
Jun 12, 2019 07:21 AM
graham11
Dec 3, 2017 11:46 AM
thedeamon
Aug 31, 2014 08:58 AM
