Headlight issues
Old Jun 25, 2009 | 07:17 AM
jaguar1986's Avatar
Default Headlight issues
1986 XJ6, high beam headlight, left hand side, right hand drive car, fuses ok, no life, bulb apparently fine according to the mechanic....any ideas troops?
Old Jun 25, 2009 | 05:01 PM
Thermo's Avatar
Veteran: Navy
First, is there power on the high beam wire at the bulb base? If yes, then you have a bad bulb base, replace the base. If no, then remove the high beam bulb and pull the fuse for that high beam. Now, using a multimeter, do you have power on one side of the fuse holder and not the other when attempting to turn on the high beams. If no power on either side, you have a wiring problem inside the cab of the car (don't have the diagrams or I would take it further). If you have power on 1 side (shouldn't have power on both sides), then your problem is in the engine bay of the car. Unfortunately, this is most likely going to require replacing the whole wire run from the fuse box to the headlight switch to eliminate the problem.
Old Jun 25, 2009 | 10:43 PM
jaguar1986's Avatar
Have got it booked in with the local auto sparkie tomorrow morning; I'll post what info I can get afterwards, hopefully will help someone else.
Old Jun 28, 2009 | 02:53 AM
jaguar1986's Avatar
Default Solved
Burnt out wire and connector...sorted this one, now for the rest of the problems!
99xk8guy
May 28, 2024 09:36 PM
avern1
Sep 8, 2015 06:25 PM
avern1
Sep 6, 2015 04:22 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
