headlight problems highbeam/lowbeam
Old Mar 25, 2009 | 11:43 PM
JagtechOhio's Avatar
The headlight relay for your XJ6 is just forward of, and slightly below, the brake master cylinder (assuming this is a U.S. left hand drive car). It is a large rectangular silver relay, Hella manufacture. If you look on the inboard relay connections, you will see a pair of blue/ red wires (low beam), a pair of blue/ white wires (high beam), and a blue wire (feed from headlight switch). In your case, if you swap the blue/ red and the blue/ white connections, you should have all four highbeams... and darkness when you hit the flash switch and operate the relay, no lowbeams. That will confirm that the relay is bad: no power to terminal 56a in either position, but fuses and lamps all in proper working order.
If that's the case, and you want a good used original equipment relay, please click on my screen name above and send me a private message.
If the relay tests OK and you still have only low beams, you'll need to do some checking with a testlight. Doug Dwyer posted some troubleshooting tests for these circuits about two months ago, I didn't read the post but he is a credible source and the fuse and bullet connector problems are probably discussed in detail there.
Old Mar 26, 2009 | 05:37 AM
Jose's Avatar
Dixie,
which Fuses have you checked? the ones in the engine compartment located near the brown coolant tank?
there are 5 fuses there in the little fuse box: 1 for each headlamp, and the fifth is for the auxiliary cooling fan located under the front bumper.
Jose
Old Mar 26, 2009 | 09:29 PM
Doug's Avatar
JTO and Jose have given you plenty to go on but here's the checklist that was mentioned
http://www.jag-lovers.org/xjlovers/xjfaq/headlamp.htm
Old Mar 27, 2009 | 07:36 AM
Doug's Avatar
The headlight fuse box is on the left side, near the coolant tank, as Jose said. The plastic cover is, oh, maybe 1.25" x 3.5". You can't miss it.
Not sure about the other fuse you mentioned. The horn fuse is in an in-line fuse holder approximately above the battery...but that's a long way from center. Jaguar did use a lot of mysteriously placed in-line fuses, though.
Old Jun 17, 2009 | 01:16 PM
N3FOL's Avatar
Default Relay
I think I replaced my relay long time ago and my headlights still don't work. The link given by Doug seems to be the best way to start in troubleshooting the problem. When I get home, I will have to start cleaning contacts and may change fuses along the way.
99xk8guy
May 28, 2024 09:36 PM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
