heat to feet
Hi
series 2 can some one tell me how set the heater controls so that i get heat to my feet
windscreen demister work fine nice and hot with lots of fan assite but nothing at my feet
Here's some quick reading:
https://www.jaguarforums.com/forum/x...basics-178059/
When the (correctly functioning) system is in heating mode most of the air is automatically sent to the footwell outlets. There's no driver-controlled input needed or even available.
Quick first test:
With the engine warmed up and the mode control set to "Auto", slowly turn the temp control from one extreme to the other. You should hear a faint whirring from behind the dash.
Do you?
Quick first test:
Do you?
contact https://www.jag-aire.com/ if checlkist above does not resolve issue. Owner is very helpful and manufactures replacement amplifiers if it turns out your amplifier has failed.
