heat to feet
Old Nov 30, 2022 | 03:57 AM
grumpy dad's Avatar
Default heat to feet
Hi
series 2 can some one tell me how set the heater controls so that i get heat to my feet
windscreen demister work fine nice and hot with lots of fan assite but nothing at my feet
Old Nov 30, 2022 | 06:18 AM
Doug's Avatar
Here's some quick reading:
https://www.jaguarforums.com/forum/x...basics-178059/
When the (correctly functioning) system is in heating mode most of the air is automatically sent to the footwell outlets. There's no driver-controlled input needed or even available.
Quick first test:
With the engine warmed up and the mode control set to "Auto", slowly turn the temp control from one extreme to the other. You should hear a faint whirring from behind the dash.
Do you?
Old Nov 30, 2022 | 10:44 AM
Jose's Avatar
contact https://www.jag-aire.com/ if checlkist above does not resolve issue. Owner is very helpful and manufactures replacement amplifiers if it turns out your amplifier has failed.
Old Nov 30, 2022 | 06:05 PM
grumpy dad's Avatar
Hi
Thanks for the info but our car has not got aircon
and is a UK car
Old Nov 30, 2022 | 06:10 PM
Jose's Avatar
Originally Posted by grumpy dad
Hi
and is a UK car
ok, then it is down to vacuum or Servo. No amplifier to worry qbout.
Pistnbroke
Dec 3, 2022 11:07 AM
baudrate
Dec 13, 2017 08:57 PM
Wingrider
Nov 7, 2017 07:53 AM
Biff Baxter
Jul 6, 2017 09:44 AM
VinnyT
Jan 25, 2016 07:46 PM
