Heater Flap Positions
Old Jun 23, 2021 | 02:33 AM
adenshillito's Avatar
Default Heater Flap Positions
Heater Unit Series Two early model heater only
Problem I have is figuring the 'set' position of some of the internal flaps of the heater. (see pictures) I am not sure (a) if the wire original wire had a spring at either end or just one at the left as in the diagram, and (b) whether the armature is in closed or open position when the pulley tension in pulled left or right (or knob position at top or bottom). This armature effects the lower flap near the floor of the unit but-
I cannot figure whether having the FLAP CLOSED stops HOT AIR traveling into the cab of the car OR whether having the FLAP OPEN dilutes the hot air with a cold intake to reduce heat.
I can imagine it could be doing either. The knob set to top is HOT and set to bottom is VENT.
the armature as positioned with the lower/floor flap inside the heater in it's CLOSED position
the armature as positioned with the lower/floor flap inside the heater in it's OPEN position
Old Jun 23, 2021 | 05:58 AM
Jose's Avatar
I think that when you turn the engine OFF, the servo returns the flaps to OFF or NEUTRAL position.
in my Series 3, the flaps in the blower cases return to closed position when I turn the engine OFF even if I shut the engine with the a/c switch ON, But the Defroster flaps open. Try and figure that.
Old Jul 5, 2021 | 05:40 PM
with this being a primitive series 2 early heater only option it seems a bit less developed than that. has me muddled at any rate.
Old Jul 5, 2021 | 05:44 PM
sat this aside for a bit. looking again and still cant figure the exact underlying logic of the lower flap, whether it is directing heat or diluting it with cool air.
12C
Jan 11, 2021 04:44 PM
JessN16
Dec 7, 2018 08:19 AM
Adison
Oct 26, 2016 05:43 AM
dickc
Sep 21, 2015 02:04 PM
gregh
Oct 16, 2012 02:56 PM
