Hinge Spring XJ6
Old Oct 29, 2014 | 08:09 PM
Jimmysea's Avatar
Default Hinge Spring XJ6
See attached photo of a rear door hinge, bottom.
Does anyone know how to remove the spring?
Old Oct 30, 2014 | 01:59 AM
Jose's Avatar
never done it but if you securely bolt the hinge to a solid surface like a tree, then use a large pry bar on one side of the "U" to push down on the spring, it should slide down enough to come out.
use goggles for protection in case that thing comes out flying.
Old Oct 30, 2014 | 10:42 AM
JagCad's Avatar
John:
I know how to remove t! I'm usually good at those things. It is the put t back that stalls me often! "Joke"
Cut it off with a grinder. Caveat, secure it or release the energy first.
Seriously. Might the spring come out easily the hinge is in the closed position?
Carl
Old Oct 31, 2014 | 08:04 AM
Jimmysea's Avatar
It's the spring I need to replace one thats broken...
Old Oct 31, 2014 | 04:40 PM
Jose's Avatar
it's probably a lot easier to go to a salvage yard and pull one from a salvage XJ.
Old Nov 1, 2014 | 01:03 PM
davidboger's Avatar
Jose is exactly right...
Just secure it and use a large pry bar to push down on it.. It has enough flex to come off the hinge...
It's a lot tougher to get the new one in place... And remember the location exactly, as they can be put on upside down and backwards...
David
Everyday XJ
Old Nov 1, 2014 | 03:06 PM
Jose's Avatar
hi David,
just pull one from your cars and sell it to him ? saves a lot of headache !
scooternva
29
Mar 25, 2025 12:45 PM
Bc xj
Sep 17, 2015 06:34 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Don R
Sep 14, 2015 12:34 PM
Tar
Sep 6, 2015 11:24 AM
