Horn stuck on, and it's not the steering column
Old Jun 17, 2014 | 12:54 AM
exeterxj12c's Avatar
Default Horn stuck on, and it's not the steering column
1987 Jaguar XJ12 Vanden Plas Canadian beast. Horn should function by grounding the green wire of the relay via the horn push, connecting the horn to power. Horn wires were detached, so I reinstalled. Relay was missing, put in a known good one. Fuse was blown behind battery, put in a new one. Now the horn is so happy it won't stop. Pull the under-dash fuse and the horn will stop. On the steering column, there's a little black wire which should connect the column to ground, and pulling that should be as good as pulling the fuse, right?? Pulling it doesn't stop the honking. I'm basically trying to track down where this horn is getting a permanent ground and I'm not finding it.
-John
(btw I'm not that new, but I couldn't get my old name working)
Old Jun 17, 2014 | 04:20 AM
hooter's Avatar
on my 86 xj6 the problem was the spring that makes the contact on the column at the bottom had come adrift and wound itself around the inside giving me the same result as yours
Old Jun 17, 2014 | 11:27 AM
john_cook12's Avatar
this was exactly my problem as well - I had trouble diagnosing it because after pulling fuse, adjusting, and reinserting fuse it would stop but then it seemed to get more frequent or to start up again after the front of the car would get wet (washing, heavy rain, etc)
Old Jun 18, 2014 | 07:35 AM
Thank you for the replies. I'm certain you are correct about the spring. Adjusted the steering column out and the problem is gone
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
jluckcuck
Nov 6, 2015 07:49 AM
Ragn0r
Sep 29, 2015 10:38 AM
