How do I open the trunk when the lock/latch is jammed?
Old Apr 7, 2016 | 05:23 PM
tdyer's Avatar
Default How do I open the trunk when the lock/latch is jammed?
Hello! I have a 1971 XJ6. The chrome trunk release handle has sustained very slight sideways damage, just enough to prevent it from rotating and releasing the trunk lid. Can anyone tell me how I get in the trunk? One person said I have to take the back seat out but is there any way to remove the lock or otherwise release the trunk from the outside? Thanks. Tim
Old Apr 7, 2016 | 05:41 PM
icsamerica's Avatar
Try pushing down vigorously on the trunk edge while jigging the release handle.
Metal behind the seat is almost solid with just a few small perforation so I don't think route will work unless you are willing to cut an access panel and have really long arms.
The only way I know of is to drill a hole in the rear trunk panel behind the license plate. It needs to be about 1 inch off center closer to the USA passenger side and use a needle nose pliers to actuate the rod. You can use a grommet plug to cover the hole when done
I hope someone else chimes in with a no cut method.
Old Apr 7, 2016 | 06:38 PM
tdyer's Avatar
Oooo....good answer! Thanks very much. I like the idea of drilling out the lid behind the plate better than crawling in from the inside anyway. Thanks very much! Tim
Old Apr 7, 2016 | 11:43 PM
Tar's Avatar
Tar
Before you start drilling, it's worth a doing a quick search through the forum. This has come up before (most things have ��) and I seem to recall there's a way to jiggle the linkage via the slots for the license plate bolts. Good luck.
Andrew.
Old Apr 8, 2016 | 07:09 AM
JagCad's Avatar
I recall at least one of those "stuck boot lid" threads. In that case, some fabric from stuff in the boot got into the latch. A padded pry bar to add up force while pushing on the release popped it open.
A study of a similar car or a parts catalog to become familiar with the
mechanism would help.
Good Luck.
Carl
holding the latch op , plus s
2010 Kyanite XFR
May 13, 2016 05:37 PM
wforslund3
Mar 31, 2016 12:14 AM
8pockets8
Mar 25, 2016 09:03 AM
isarobertson
Mar 19, 2016 09:26 AM
anton5678
Mar 14, 2016 11:04 AM
