How to remove '84 S3 power antenna mast
Old Aug 31, 2013 | 07:17 PM
Roger Mabry's Avatar
Default How to remove '84 S3 power antenna mast
I am installing the power antenna into a '72 S1 XJ. It has two holes for a stock Jaguar power antenna but they are considerably smaller than those in the S3.
I need to separate the antenna mast from the motor to be able to route the mast cable into the spare tire well. The antenna does power up with 12V applied.
Old Sep 1, 2013 | 03:45 AM
S.Bunzel's Avatar
I hope this will help.
Attached Thumbnails How to remove '84 S3 power antenna mast-ant1.jpg   How to remove '84 S3 power antenna mast-ant2.jpg
Old Sep 1, 2013 | 09:28 AM
Default Thanks for information
I will try to enlarge the two holes to be able to use the Jag method. It does remove easily out of the S3...
The holes in the S3 are much larger than the ones in the S1, that early power antenna must have been totally different...have no specs on that one.
Old Sep 1, 2013 | 06:12 PM
Default I enlarged the hole in the spare tire well
It worked, I used string to pull the antenna mast through the old smaller hole into the fender.
The antenna fits well and will be totally mounted (the motor and delay relay) tomorrow as I have to move around the fuel system stuff to make room.
Attached Thumbnails How to remove '84 S3 power antenna mast-s3-antenna-installed.jpg
Old Aug 9, 2014 | 12:38 PM
Joeg123's Avatar
S Bunzel.. Thanks. Have a1986 Jag xj6 Vanden Plas . Do you know whether the instructions will work for this model? Also what is the source of the instructions?
I couldn't find them in my Haynes manual>
Jul 9, 2018 01:44 AM
eurotire
Sep 18, 2015 07:27 AM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
chatmanx
Sep 11, 2015 07:17 PM
