How to remove abs ring (replacing front rotors)
Old Jul 4, 2018 | 09:50 AM
Martin Kunz's Avatar
Default How to remove abs ring (replacing front rotors)
Hi,
i am rebuilding/replacing my front brakes.. how can i remove the abs ring from disc/hub assembly?
How is the abs disc held in place? What tool do i need to remove it?
Regards,
faljse
Old Jul 4, 2018 | 10:24 AM
JagCad's Avatar
Wrong forum?
The cars here do not have ABS?
Carl
Old Jul 4, 2018 | 11:07 AM
Its a Daimler Double Six, which should be very similar to a XJ12 S3
Old Jul 4, 2018 | 11:27 AM
Doug's Avatar
I'd use a small gear puller to remove the ring.
Often you can gently tap them off with a drift and hammer if you have clear access to the backside....which you don't.
Old Jul 4, 2018 | 11:31 AM
Doug's Avatar
Originally Posted by JagCad
Wrong forum?
Only the last of the Series III V12s had it, Carl. Circa 1990-92, I think? I'm guessing maybe 2500 cars in all?
Old Jul 4, 2018 | 01:56 PM
JagCad's Avatar
Always learning, Doug, thanks !
Carl
Old Jul 4, 2018 | 02:35 PM
thx, will try (just ordered a gear puller...)
Am i gonna need a hydraulik press to get it back on?
dsetter
Jun 17, 2025 02:32 PM
sts-v
Feb 10, 2018 04:09 PM
daboss085
Sep 20, 2013 11:49 PM
Jeeves12
Jan 12, 2013 07:07 PM
