How to remove air flow meter black cap
Old Mar 12, 2021 | 04:28 PM
worzella's Avatar
Default How to remove air flow meter black cap
Sorry all...I know I read it somewhere but can't locate it. How do I remove this black cap on AFM? No screws so seems glued on? Heat?
Old Mar 12, 2021 | 07:31 PM
Glued.
Those I needed to remove, wide blade screwdriver, VERY BLOODY CAREFULLY, and work around the edges. Sadly, damage can and will take place on those edges, but with care, they be minor and can be dressed out later.
I have cracked a few, too much haste.
Heat would be good, but it lives in HEAT, so take care not to melt the thing.
Old Mar 13, 2021 | 05:10 PM
Fraser Mitchell's Avatar
I had to have the top off the AFM on my 1980 some time in the mid-90s when I got the dreaded engine cut-out syndrome. At the time the reason was not well documented, so it took a long time to bottom it out. The reason was the pair of very small contacts inside the AFM that close when the engine starts, and maintain volts to the fuel pump relay. Over time the springiness of the blades reduces and one has to basically rebend them to make better contact and at the same time clean the contacts. So the top of the AFM had to come off.
As I recall, I removed the AFM to make it easier to release the top, and could then cut away the glue and gradually levered off the cover. You have to be very gentle as they don't make the covers anymore !! I forget what glue I used to replace the top with, sorry !
malchick69
Apr 21, 2019 08:08 PM
macdoesit
Sep 3, 2017 06:54 PM
J Chandler Buehler-Werline
Jul 15, 2015 12:02 AM
solerydr
Sep 29, 2013 02:34 PM
christo
Jan 31, 2009 11:33 AM
