I need help diagnosing a problem
Old Jun 26, 2017 | 03:12 PM
Thomas Eggleston's Avatar
Default I need help diagnosing a problem
Ok, so when i am dricing along in my 1985 XJ6, ocassionally it will lose power and the engine sputters. So far, i dont have a whole lot of information about it, other than it doesn't ALWAYS happen, and it smells of gasoline right afterwards.
Old Jun 26, 2017 | 04:51 PM
o1xjr's Avatar
Welcome to the forum Thomas,
When you get a moment please post an intro in the new member area.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Jun 26, 2017 | 10:59 PM
Doug's Avatar
Although intermittent is there any pattern at all? Only when cold? Only when fully warmed up? Only when on the left (or right) fuel tank?
Have you inspected for any stain/evidence of an actual fuel leak?
If it only happens when cold then you might have the double-fueling issue, the fix described here:
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
For more reading on 'rich mixture' problems....which could give a raw gas smell if severe enough.... take a peek here.
XJ6 Series - EFI Rich Mixture
Old Jun 26, 2017 | 11:18 PM
now that you mention it, it only really seems do do it when fully hot and usually at 55 mph and higher,though it has done it at around 40 as well. currently i am only able to use the left tank because the sending unit in the right tank is bad.
Old Jun 27, 2017 | 09:52 AM
JagCad's Avatar
Right tank leaks at the sending unit? Or merely, you can't tell if there is fuel in it and if so how much or empty!!!
My thinking is that if feasible, put some fuel in it and run on it and see if the issue moves with it or is gone.
A help in isolating the fault.
Swapping in a new sender isn't all that bad. I've ever done it. But, Elinor did and posted a neat tutorial.
Carl
Old Jun 27, 2017 | 10:52 AM
Carl
The tank doesnt leak, I just cant tell how much fuel is in it
Old Jun 27, 2017 | 10:59 AM
Dutch-Cat's Avatar
You could swap the senders and work from there...
Have you checked the fuel filter on the left tank?
Could be some rust clogging it...
Old Jun 27, 2017 | 11:04 AM
I'll give it a shot, thanks
Old Jun 27, 2017 | 08:11 PM
Jose's Avatar
errr, if the car is a Series 3, there is only one fuel filter.
Old Jun 28, 2017 | 02:54 AM
Dutch-Cat's Avatar
Ok Jose, didn't know that...
Well TS....check the fuel filter then.... ;-)
And all the others a p.o. could have installed....
