Ignition switch
Old Aug 16, 2023 | 02:56 PM
denis4x4's Avatar
Default Ignition switch
All of the plastic behind the ignition switch has crumbled! Is there a work around that would allow an on-off switch with a push button starter? I have tried a number of new and used vendors and the parts do not exist. The car sits here unable to be started! About ready to sell it for scrap!
Old Aug 16, 2023 | 05:06 PM
David84XJ6's Avatar
https://www.jagbits.com/product/DAC1422.html
This may be part you are referring to.
Rgds
David
Old Aug 16, 2023 | 05:54 PM
Jose's Avatar
yes there might be a workaround and the parts do exist from Jaguar cars.
The 1960's Small Saloons before the XJ had a "Ignition ON / OFF" switch with Key, and then you press a push button to crank the engine. Can it be adapted to the XJ ? I have no clue.
I have both parts in my classic S type parts website that you can look at
https://classicstypeparts.webstarts.com
Old Aug 16, 2023 | 07:22 PM
Doug's Avatar
Looks like you have a Series II, Yes?
I think a switch from a Series III will work
More possible sources:
https://www.ebay.com/itm/155453242549
https://www.terrysjag.com/product/DAC1422.html
Also try David (great guy) at :
https://everydayxj.com/
m0t0rm0uth
Aug 19, 2023 01:43 PM
Artfulkatana
Feb 14, 2023 11:59 AM
tedjan
Oct 30, 2021 02:09 PM
lyonsfin
Jan 27, 2020 08:59 PM
86JAGVP
Aug 19, 2011 11:45 PM
