Ignition switch XJ6 series 2
Old Mar 21, 2024 | 04:15 AM
stan73's Avatar
Default Ignition switch XJ6 series 2
Hello,
There is returning wire from ignition switch socket
(white/yellow color) , I can’t find where have to connect round lucar ?
Old Mar 21, 2024 | 05:36 AM
Stan,
White/Yellow is for the Starter Relay supply, and related to Pos 3 on the switch.
I dont remember a stray wire on any of mine, but markets do differ in many areas.
My code scibe is attached.
File Type: doc
Old Mar 21, 2024 | 06:39 AM
Doug's Avatar
That connector may have been unused since day one.
Depending on market, as Grant says, some cars might have had xxx-device that required "+" voltage when cranking. Without more coffee I can't suggest what it might be.
Is there anything not working on your car?
Old Mar 21, 2024 | 02:56 PM
stan73's Avatar
Thank you!
I had to rebuild all switches because long storage, all of them blocked. First attempt to start the engine was positive. We have long way ahead :-)
File Type: mov
Pristine97XK8Convertible
Sep 8, 2021 09:54 AM
joebsummitt
Jan 3, 2019 08:30 AM
stroud09
Dec 18, 2018 03:47 PM
whattrouble
E type ( XK-E )
May 23, 2013 09:31 AM
86JAGVP
Aug 19, 2011 11:45 PM
