Inner joint
Old Nov 7, 2016 | 07:51 AM
Jaguar1981's Avatar
Default Inner joint
Hello.
I am going to changes the inner joint on my Jaguar XJ 6 from 1981 (series 3) but there is a problem I do not understand. On the rack there is a threaded tap on witch I shall mounted the inner joint, in which there is a threaded hole and in the hole there i a spring and a (spacer) washer. Now the question: I do not know what work the spring does and how I shall mounted the inner joint to the racket. So if anyone knows I would be glad to hear from you.
Anders from Sweden
Old Nov 7, 2016 | 09:04 AM
JagCad's Avatar
Anders:
It is probably a language and nomenclature issue.
But, I am confused, and I suspect others are as well.
At least three possible.
1. Steering rack?
2. Center drive shaft universal.
3. Transmission mount.
4. One of the rear half shafts in the Independent rear suspension.
Clarify and loads of help will appear. Most with greater skills than mine.
Carl
Old Nov 7, 2016 | 10:54 AM
Anders,
If I understand your question correctly, here's a link to an answer.
https://www.jaguarforums.com/forum/x...0/#post1226219
I hope this covers it.
And then when you get a minute, please stop by the New Members section here;
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and post an introduction.
Welcome to our playroom from ElinorB.
Old Nov 7, 2016 | 11:46 AM
Jaguar1981's Avatar
Default Inner joint
Originally Posted by JagCad
Anders:
1. Steering rack?
Carl
I mean:
Steering rack
innerjoint between the steering rack and tie rod.
Anders
Old Nov 7, 2016 | 11:47 AM
Jaguar1981's Avatar
I mean:
Steering rack
Anders
Old Nov 7, 2016 | 01:05 PM
Originally Posted by Jaguar1981
I mean:
Steering rack
Anders
Yes, Anders, the link I gave takes you to the specific post that deals with that.
The inner tie rods come with that inner joint attached at the factory;
This is a picture of my old inner rod (top) and the new one (bottom), with the outer tie rod ends installed by me.
When installed on the rack they look like this; outer ends left off to accommodate the protective boots:
As far as I'm aware the large nut assembly on the left of the above picture cannot be bought separately. However, others may have more information.
Old Nov 8, 2016 | 03:26 AM
Jaguar1981's Avatar
Yes I recognize that inner rod. When I removed the inner rod there was a spring and a(space)washer inside the inner rod and I am not sure how to mount the inner rod, because I do not know what function the spring and washer has.
Anders
Old Nov 8, 2016 | 09:35 AM
OK, there were different manufacturers building steering racks for Jaguar in those days and yours may be different from mine. But if you go the the online catalog of SNG Barratt you can find exploded drawings of most components.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old Nov 8, 2016 | 09:45 AM
JagCad's Avatar
If I were to guess based on a function analysis, I'd say the washer
and spring serve to keep the male part seated in the female part.
Carl
Old Nov 27, 2016 | 01:35 PM
Jaguar1981's Avatar
Default Inner joint
Hello.
I still have problems with mounting inner joint to steering rack on my Jaguar XJ 6 from 1981 (series 3). To be more clear on the problem I will send a pictures from work shop manual (57-2). in the pictures you can see the number 6 stuff (spring and packing washer). Witch function and how mounting?
Anders
File Type: docx
