Installation of XJ6 Series 2 Dash Pad
Pulling out the dash pad was very easy. The same cannot be said of reinstalling the dash pad. It’s a nightmare, if anyone has some hint or video of how to install it, it would be very much appreciated.
Lots of Jag repair videos on You Tube. Might be something there about dash pads.
But where, specifically, are you having a problem?
My experience is with Series IIIs, which I think are the same, and the dash pad pretty much just slots into place.
The biggest problem is getting it over the steering wheel.
So, you must start with that side first, sort of. Because, if you remember, when you pulled it out, you pulled mostly straight and slightly up to clear the wheel, and then everything else followed.
When reinstalling the dash cap, get it over the wheel, level it best you can, then with the front slightly higher to avoid the demister vent foams, finagle it into place, making sure the map light wires are in their proper place and the rear lip is in position.
Don't loss your temper.
Easier said than done..............
thanks for your reply
Purplemaverick
Aug 13, 2017 08:31 AM
