Jaguar 6 cylinder motor # CS594
Old Oct 22, 2019 | 08:17 PM
smaceng's Avatar
Default Jaguar 6 cylinder motor # CS594
I am trying to determine what engine is in a Proteus recreation believed to be from a XJ6 1972. It is a 2 SU carb. DOHC 6 cylinder with no electronic aids. The motor number on the bellhousing flange is CS594. Any ideas?
Thanks,
Scott in CA
Old Oct 22, 2019 | 08:34 PM
smaceng's Avatar
Another number found on the bellhousing which agrees with the VIN plate is 8L41420 for the Proteus.
Thanks,
Scott in CA
Old Oct 23, 2019 | 09:41 AM
Jose's Avatar
you can also find the engine number cast on the right bottom side of the block, at the top edge where it meets with the oil pan near the oil filter and starter.
Old Oct 23, 2019 | 10:27 AM
smaceng's Avatar
Based on Jag-lover website, the 8L41420 engine number agrees with it being a 4.2 Liter XJ6. I guess what I would like to know is what series is this engine.
Thanks, Scott in CA
Old Oct 23, 2019 | 10:43 AM
Fraser Mitchell's Avatar
The "8L" indicates a later long-stud 4.2 litre block. The first long-stud blocks were prefixed "7L". The later block was supposed to be stronger, but really the biggest problem with either is cracking between the bores that eventually leads to head gasket failure.
Old Oct 23, 2019 | 11:24 AM
Robert Laughton's Avatar
My guess is 1975-1977.
I think all the S1's had 7L motors
Rob
Old Oct 24, 2019 | 04:11 PM
Rob
Yes, your pretty much there, but the 8Ls continued beyond 1977 because my 1980 XJ6 had one. I'm not sure if 8L applies right to the end, or they used another code for the "slotted" blocks.
Brandon Wright
Sep 1, 2016 04:38 AM
tat2ist
Dec 21, 2015 11:04 AM
jaguar jon02
Apr 5, 2015 06:36 PM
noterman
Nov 3, 2014 08:22 PM
