Jaguar xj6 series 1 Borg warner 12 filter
Old Dec 19, 2013 | 03:31 PM
machimba's Avatar
Default Jaguar xj6 series 1 Borg warner 12 filter
Hello,
Does anyone know if the filter for the automatic transmission bw 12 of a XJ6 4.2 series 1 is reusable after cleaning it or must be changed?
Thanks ,
Best regards
Old Dec 19, 2013 | 05:51 PM
Memory, HAHAHA.
It is similar to the BW65/66 and is a Stainless or Brass mesh.
Wash it out, dry it off, reuse it.
I reckon thats what I did on our 2 V12's that had that transmission, a very long time ago.
Old Dec 20, 2013 | 06:28 PM
machimba's Avatar
Hello Grant,
Thank you very much, I will change the fluid and filter soon. Strange noises when shifting down....
Regards
Old Dec 21, 2013 | 02:52 AM
If it were mine, and its not, I would simply drain the fluid, either via the drain plug (if it has one), or the dipstick tube securing nut.
Then refill with fresh fluid, go for a 50km drive, as many gearchanges as possible, drain it again, refill it again, repeat this until the colour of the draining fluid is the same, or very close to, the colour of what you are pouring in. This is usually about 6 times on these older transmissions with the larger amount of fluid being contained in the converter.
Then drop the pan, wash or replace the filter, refill again, and forget for 12 months.
This "sometimes' will sort that down change noise, but not always. The BW12 (also known as an FMX), is a very tough cast iron transmission, and failures are rare, except for 2nd gear band, which does fail with age and fluid neglect.
Old Dec 23, 2013 | 04:42 AM
machimba's Avatar
Hello Grant,
Thanks, I´ll do it.
adenshillito
Feb 17, 2016 07:05 AM
celticpiping
Sep 18, 2015 06:17 PM
Series1fan
Sep 5, 2015 08:02 AM
Rhett
Aug 28, 2015 11:30 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
